Hi everyone - I'm new here, hope you have some insight into my current dilemma:
I have a 1999 Volkswagen Passat GLX V6 Sedan (Front wheel drive) with Tiptronic automatic transmission (mfg. by ZF, model 5HP19FL). The transmission was rebuilt 2 years ago by the local AAMCO shop (now out of business). It had 62K miles at the rebuild, and I've put on 12K since the rebuild.
Recently it's been occasionally shifting rough and/or shuddering. Can't pin down exactly which gear or driving conditions trigger the problem, but it is worrisome. I scanned the transmission computer and found it was reporting no codes.
I took it to my independent VW specialist and he checked the transmission fluid level. Level was fine, but to our surprise the fluid was cherry-red, not golden colored like the OEM fluid.
ZF specifies Esso LT-71141 fluid or equivalent for this transmission - Pentosin ATF-1 for example. Both are quite expensive, about $15/L. AAMCO charged me only $22.00 for the entire 9L of fluid they put in my transmission, which leads me to suspect that they used a cheap, out of spec substitute fluid.
So my question is, what to do next? This car has "lifetime" fluid, so no ATF dipstick. If I drop the pan and change the fluid and filter, I can only drain 5L of the 9L capacity, leaving me with a mix of old and new fluid. I have heard that there are ways to do a "power flush" via the cooling lines that would replace all 9L.
Any thoughts on whether this would be a wise or risky procedure to undertake? Any recommendations on where I can have the procedure done? I am in New York City. I do not plan to DIY this.
Thanks in advance!
Thanks in advance!
