21 Honda Pilot 9-Speed trans @40k mile, Time to change ATF?
Update:
The drain plugs are not reusable due to integrated 1 time use gaskets.
The drain plug, level check plug, and fill plug all need to be replaced at $24.34 each.
$75 for 3 plugs. 🥹
IF it doesn't leak they never know. I traded mine in. The 9 speed and cylinder deactivation and all the recall made me too nervous
Visually they won't be able to tell but if they want evidence I followed the instructions when changing the fluid, part invoices would be needed. Trading it in with no issues, no problemo.
The issues were supposedly solved with the 21's and up. Only recall is to double check the brake master cylinder torque spec and maybe an SRS seat sensor.
