Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,939
3.2 quarts ATF 3.1 in 3 quarts out, where did the rest go? 21 Honda Pilot ZF 9 Speed
Replacing the fluid on my 21 Honda Pilot right now and I figured I’d do a transmission rinse before the final fill. I drained out 3500mL quarts into a graduated 5000 mL pitcher.
This is the ZF9 speed transmission, automatic all wheel drive.
The book states that the correct replacement fluid fill is 3.5 quarts, which is 3300 mL which is confusing why 3500 came out but I do have the car on ramps so maybe that affects how much I should be replacing?
For some reason, I filled it back up with only 3200 mL. I drove for about 3 miles and have drained the fluid back into the graduated pitcher but only 3000 came out.
I’m not sure if the torque converter is somehow holding this excess capacity or what happened but I am thinking of actually filling up with 3700 mL now considering the 200 mL discrepancy.
Let’s say I overfill by 200 mL instead of the 3500 mL fill which drained out initially, would overfilling by 200mL be an issue on a transmission that has a total capacity of 7.9 quarts (7500mL)?
