Better yet- Kendall GT-1 Euro +Run Kendall GT1 Max Full Synthetic. They are made by Phillip 66 who makes MC.
Detroit Diesel Series 60s had those back in the 90s, so it's been around a while.Hold on...plastic oil pans???
And they run many millions of miles on them. I've been wrenching on them for around 10 years and only had to replace one, the rest have just needed gaskets and grommets. That's the mistake people make on them, they see a leak and change the gasket but never the grommets and that's where the leak usually is in my experience.Detroit Diesel Series 60s had those back in the 90s, so it's been around a while.
Where is Kendall motor oil even sold?Run Kendall GT1 Max Full Synthetic. They are made by Phillip 66 who makes MC.
Not sold where I liveWhere is Kendall motor oil even sold?
Never seen it on shelves in any of the stores around here.
Do you have any pics of your new G.O.A.T?Just took delivery of a 2021 Ford Bronco Sport with the 3 cylinder turbo engine, 1.5 L. I noticed that Amsoil does not have an oil recommendation on the website yet which did not surprise me as it's a brand new model. But I have a question that my dealer service department couldn't answer. I've used 100% synthetic Amsoil in everything I've owned since 1979. I noticed in the Bronco Sport manual they (naturally) recommend Motorcraft synthetic blend oil, or Motorcraft traditional old style oil, but they did not recommend Motorcraft 100% Synthetic. Wondering if there is some reason that they don't want 100% synthetic in these motors? Of if there was some logical reason? Or if they just didn't want to steer people to more expensive, or perhaps less readily available Motorcraft 100% synthetic oil? Is it a marketing thing or a technical thing? Figured if anyone would know, it would be Amsoil! Naturally I intent to switch to Amsoil as soon as they have a recommendation posted, but why isn't Ford recommending their own 100% synthetic?
If your looking to try Kendall somedayNot sold where I live
Only on line is where I’ve found it
Yes, it's a 3 cylinder turbo! 1.5L. The manual says:
Motorcraft® SAE 5W-20 Synthetic Blend Motor Oil(U.S.)
Motorcraft® SAE 5W-20 Super Premium Motor Oil
Specification
WSS-M2C960-A1
Oil change intervals called for are whenever the oil life monitor tells you to, expected to be 7500-10000 miles in normal driving, obviously more often in more harsh or "extreme" use and in dusty and dirty areas.
TGDI 3-banger? I definitely wouldn’t want to run any blend, Motorcraft or otherwise.
It would be a high-quality full-synth, for sure.
Probably a good, low-Noack 10W-30, at least. Possibly a Euro 5W-30.
I think it is true that thicker oil can change the “feel” of an engine, possibly adding some slight drag. ”Drastically” is a bit hyperbolic, I think.
Ford simply updated to GF6/SP with their in 20/30... grade specs.
So, I recommend any 5w20 full synthetic SP/GF6 oil. If it were mine, I'd use a 5w30 synthetic. But, its a 3 cylinder so maybe the mud oil will reduce power/mpg drastically. Use the Ford Motorcraft oil until all the brands update their recommendations.
