Looking for some feedback here guys. Want to pick up a torque wrench to use it both for plugs during fluid changes as well as on the lug nuts. My civic is rated at 80ft*lbs, Pilot at 92. With that said, 10-80ft*lbs wrench is good for plug/civic nut lugs but no so good for pilot. Bigger wrench 20-150 ft*lbs would cover all three applications but it is also 4' loner with total length of 18". Has anyone used these big of the wrenches for tightening up drain plugs? was it ok or way to big? I'm a little concerned regarding the space limitations since I don't have an access to the lift and the car would either be on the ramps of jacked up sitting on the stands. thanks guys
