Originally Posted By: CrawfishTails
KrisZ, you have evidently still not heard of BMW's own migration to 20 oils. They are a conservative, slow-moving company, yet they have LL-12 FE, LL-14 FE, and a revised LL-01 FE, all which spec lower-HTHS oils. They are catching up with Ford, Chrysler, GM, Mazda, Toyota, Jaguar, Honda, all which run 2.6 HTHS oils without incident, many times in engines that used to "demand" a 30 oil. BMW back-specs LL-01 FE to all current engines that they used to "insist had to have" 3.5 HTHS, so they are backing down, and so am I, from high HTHS in many, many cases.
Also, you need to educate yourself on the many technical papers I've seen where synthetic oils perform better than conventional in Boundary Lubrication conditions, and the effects of moly-boron (Ceratec) AW-FM additives. Also, you haven't seen an E60 BMW run 0w-20 with no ill effects like I have for three years. Also, you didn't even notice or acknowledge that I actually recommend using a modern synthetic (any name brand) 5w-30 or 0w-40, and I do this based on the extensive dexos1 tests I know of that all the big name brands meet in a synthetic xW-30 flavor, and of course I've said LL-01 is fine, just a bit heavy, to use.
KrisZ, I sincerely hope you read a lot of engineering papers and review the news of BMW trends before naively answering these posts.
I've not seen any evidence of BMW back-spec'ing any of their previous engines to the new FE grades. They have produced engines that call for/allow thinner lubricants and those lubricants are the ones that carry the FE (Fuel Economy) spec. The LL-01 FE spec is an old spec and discussed in this thread:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2688085
QP also posts a nice chart (the same one he posted in this thread) in there showing which engines allow which approvals. There is some overlap. Some engines can use LL-04, LL-01 and LL-01 FE. Others are more specific.
The approval/allowance of oils not >=3.5cP is not a new thing for BMW. As QP point out in that thread, it had been going on for at least 10 years at that point (2012). They have continued that and now have some engines that call for a 20 weight as well.
I think you'll find that the engines you think were back-spec'd are on that chart for either approval. The OP's engines isn't one of those engines though
The applicability of the spec's is covered quite well here:
http://www.lubrita.com/news/195/680/Lubrita-Engine-Oil-Recommendations-for-BMW-cars/
Quote:
Quality levels / application and overview of BMW oils specifications:
"BMW Longlife-01" (LL-01)
• This quality is the minimum requirement for all BMW gasoline engines from model year 2002
and for BMW diesel engines without particle filters from model year 2003.
• All older BMW engines can use this quality.
• To avoid customer irritation, no product names containing the designation "diesel" are permitted.
• For BMW M GmbH engines, this quality is only permitted in new, designated models with S55 or S63 engines.
"BMW Longlife-01 FE" (LL-01 FE)
• Due to the low HTHS viscosity in comparison to the BMW Longlife-01 specification, these oils may only be used for the BMW gasoline engines released for this oil. At present, these include all current gasoline engines (N1x, N2x, N4x, N63, N74).
"BMW Longlife-04" (LL-04)
• These oils are permitted for all BMW diesel engines with or without particle filters.
• This quality also applies to BMW gasoline engines. At present, the type approval is limited to the
EU area together with Norway, Switzerland and Liechtenstein.
• For BMW M GmbH engines, this quality is only permitted in new, designated models with S55 or S63 engines in the EU area together with Norway, Switzerland and Liechtenstein.
"BMW Longlife-12 FE" (LL-12 FE)
• Due to the reduced HTHS viscosity in comparison to the BMW Longlife-04 specification, these oils may only be used for the BMW diesel and gasoline engines released for this oil.
• These oils are suitable for new BMW diesel engines from model year 2013, although only for specially released engines in accordance with the release list. Essentially, the Nx7K1, Nx7U1 and Nx7O1 engines have been released at present. This quality is generally not permitted for engines with 2 or 3 exhaust turbochargers.
"BMW Longlife-14 FE+" (LL-14 FE+)
• Due to the low HTHS viscosity of 2.6 mPa・s, these oils may only be used in BMW gasoline engines released for them.
• These oils are only suitable for new N20 and Bx8 gasoline engines from model year 2014.
• At present, the type approval is limited to the EU area together with Norway, Switzerland and Liechtenstein as well as the US market.
• This quality is not permitted for BMW M GmbH engines.
– SAE viscosities:
Viscosity shall correspond to one of the viscosity categories SAE 0W-20, SAE 0W-30,
SAE 0W-40, SAE 5W-20, SAE 5W-30 or SAE 5W-40, where the following conditions apply to the individual specifications:
"BMW Longlife-01": SAE 0W-30, SAE 0W-40, SAE 5W-30, SAE 5W-40
"BMW Longlife-01 FE": SAE 0W-30, SAE 5W-30
"BMW Longlife-04": SAE 0W-30, SAE 0W-40, SAE 5W-30, SAE 5W-40
"BMW Longlife-12 FE": SAE 5W-20, SAE 0W-30, SAE 5W-30
"BMW Longlife-14 FE+": SAE 0W-20, SAE 5W-20
