You seem to think that viscosity change due to temperature is a new phenomenon. Modern oils with a high viscosity index are actually much more viscosity stable over temperature ranges, compared to years ago. A 4x variation in viscosity is probably not such a big deal. Modern engines are designed to accommodate this range.Mobil1 0W-8 has around 4x variation in thickness simply going from 104F/40C to 212F/100C.
If this statement be true, then please explain how the oil pump/engine is able handle start up/initial warm up cycle at freezing temperatures (or even at any livable temperature for that matter) when the oil viscosity could be 10x greater than at operating temperature?
https://www.mobil.com/en-us/passenger-vehicle-lube/pds/us-xx-mobil-1-0w-8
How do you explain that auto engines even functioned decades ago, when oils were far less well designed? My dad used to put a pan of charcoal under his car in Minnesota winters back in the 60's to get it started. It's amazing that his car ran for all those years on the oil available, and the infrequent service that he provided. The oils back then were far inferior to today's synthetics.
I'm not too worried about Toyota engines and the new thin oils. The engineering by Toyota has been pretty good over the years. They are designing engines to work with these sophisticated oils.
