Purchased it 2 weeks ago , itās not my aunts Prius.200 hp , quiet , nice drive.
Thatās the combined power. In the plug in version it is even more powerful, 220 hpDoes the 200 HP spec include the battery powered motor generator?
Yes. The ICE is 150hp alone.Does the 200 HP spec include the battery powered motor generator?
Because it might be the best worst case scenario size they can build economically. Typically the best efficiency of an engine running Carnot cycle from what I remember is 40% of the peak power and rpm. If that 200HP is when running Carnot and Atkinson is another 30-40% less, it would mean that 200HP is running at 40% x 60% = 24% of peak at optimal efficiency, which makes it 48HP.I fail to understand why a Prius, a car supposedly built for efficiency, needs a 200 HP engine.
What engineering/chemistry degree do you have?Youāre right, that 0 x 8 oil is basically just city tap water. Toyota and Exxon/Mobil have no idea what theyāre doing.
If you were driving a 6.2, perhaps it would have.What engineering/chemistry degree do you have?
I tow up 10,000 foot mountain passes pulling a 5,000 pound travel trailer running 0W/20. Certainly the motor (5.3-Silverado)) should have blown up by now.
Sarcasmlogy.What engineering/chemistry degree do you have?
If you are happy with it, all good!
We need pics when you get a chance please.
I guess Toyota doesnāt know what itās doing ā¦ā¦..
Toyota knows what they are doing. Because of engine design accommodations they have determined that an 8-grade oil has sufficient HT/HS under most circumstances to prevent excessive wear in the engine. Which is fine. But it doesn't preclude the use of a higher grade to additionally help reduce wear if an owner decides to do so. It won't harm the engine.I guess Toyota doesnāt know what itās doing ā¦ā¦..
Toyotas and other brands like nissans, kias/hyundai, mitsubishi and others all say you can use many more grades in the exact same engine sold here in the US but they can't say to use multiple grades here. This is because of a stupid epa regulation saying that only the specified grade used in testing is to be stated with only minor exception like if the grade used in testing might not be thin enough for extreme cold so the documentation provides guidance on what they can do. But you can test with a higher grade and recommend that higher grade and a lower grade which I think Hyundai Kia does in some turbo engine. Most of the info on that is after page 8 specifically 9 and 10 but there's some good info on other things beginning with 1. What the oil cap states is minimum not maximum.I'm impressed. The page from the owners manual explains more about oil than any owners manual I've ever seen, and OK's the use of .... even that "heavy" 10w30 oil, and explains that it may be more difficult to start when the temperature is below zero.
I'm used to seeing the implied threat of complete engine failure if you don't use the oil spec'd by the manufacturer and labeled on the filler cap.
Iām no tribologist. However, I donāt think that what you are mentioning is a new thing. These are anti wear and anti friction additives. Valvoline Restore and Protect refers to āLiquid Shield technologyā. Of course, we donāt really know what their exact formulation is. Moly? Boron? Zinc? Titanium? If anyone knows, they are not talking.I havenāt seen it posted much here but itās new āFilm formingā additives that have allowed for practical use of 0W8 while maintaining low wear rates.
It doesn't have a 200hp engine.I fail to understand why a Prius, a car supposedly built for efficiency, needs a 200 HP engine.
