0w-30 Mobil 1 Green Cap vs. German Castrol
Originally Posted By: Nickdfresh
Utterly meaningless. That's like saying that German Castrol is a poor oil because it doesn't meet the GM4817 spec, or it cannot pass the HTO-06 spec...
Not if you ~understand~ the specs.
Again, more reading, less posting. Start with the Lubrizol links I posted, and then you can do your report in front of class.
I'm embarrassed for you.
I'll even give you a hint, A1 vs A5.
This is a really easy one.
Oil 101.
Originally Posted By: Gary Allan
This still going on?
Remember. Your oil cannot love you back. It's totally indifferent to your disposition.
You mean I'm wasting my time snuggling with the bottles?
Originally Posted By: Audi Junkie
Maybe more reading and less posting is the solution, as quite often seems to be the case recently.
Your post frequency is 7 times mine. Lack of debate preparation, arithmetic skill or both?
Your tone has been increasingly bitter lately. I am sorry if you are not doing too well.
I like GC and have found it to work well in many applications.
A smooth and quiet oil, with long drain Euro cred, by the standards it meets.
AFE is fine for those cars that can use it.
It works great in my '99 Accord on 5K drains, and I could likely run it longer.
It would in no way be appropriate for my old BMW, while GC would be just fine.
GC also works well in our Subaru.
I wouldn't like AFE for that engine.
Both good oils, either will work fine in many engines, but really a case of different horses for different courses.
It's only wierd if you do that when you're going to sleep.
Well I went to Wal-Mart tonight and looked around at oil. 0w30 Mobil 1 Green Cap is definitely A1. Mobil 1 and Mobil 1 Extended Performance said they did A5.
Wal-Mart had no 0w30 GC at all. I am going to stop by Autozone again and see if they have any in stock.
At this point, I personally would like to try a 0w30 meeting A5. So A3 is OK and A1 is the worse?
Oh, okay. Yeah, I've noticed you've a penchant for spamming with irrelevant info to compensate for the lack of a rational argument.
But feel free to let use know how the spec's are at all relevant to your bashing...
That's because you lack any ability to be socially conscious and have to resort to ad hominum...
Oil 101.
Except it's completely irrelevant to any argument presented here...
ACEA A1/B1 oils are typically low HTHS (≤3.5cP) SAE 5w30 based on API Group III base oils. The main physical and chemical requirements for ACEA A1/B1 are shown below:
Requirement Method Unit Limit
HTHS viscosity CEC L-36-A-90 cP ≥ 2.9 and ≤ 3.5 xW-20 ≥ 2.6
Sulphated Ash ASTM D874 %wt ≤ 1.3
Phosphorus ASTM D5185 %wt Report
Sulphur ASTM D5185 %wt Report
Evaporation loss (NOACK) CEC L-40-A-93 % ≤ 15
Total Base Number ASTM D2896 mgKOH/g ≥ 8.0
ACEA A3/B4 oils are probably seen in the widest range of viscosity grades. The most common being:
* SAE 10W-40 based on a mix of API Group I and Group III, or API Group II base oils.
* SAE 5W-40 and SAE 5w30 based on API Group III base oils.
* SAE 0w30 based on API Group IV base oils.
The main physical and chemical requirements for ACEA A3/B4 are shown below:
HTHS viscosity CEC L-36-A-90 cP ≥ 3.5
Sulphated Ash ASTM D874 %wt ≤ 1.6
Evaporation loss (NOACK) CEC L-40-A-93 % ≤ 13
ACEA A3/B3 oils are seen in a wide range of viscosity grades. The most common being:
* SAE 10W-40 based on a mix of API Group I and Group III.
* SAE 15w40 based on API Group I base oils.
The main physical and chemical requirements for ACEA A3/B3 are shown below:
Sulphated Ash ASTM D874 %wt ≤ 1.5
ACEA A5/B5 oils are typically low HTHS (≤3.5cP) SAE 5w30 based on API Group III base oils. The main physical and chemical requirements for ACEA A5/B5 are shown below:
I have run both Mobil 1 and GC 0W30 in a 8.0 L dodge engine. I know alot of people see a difference in NVH after an oil change but I never really notice anything. But then I don't really expect their to be much difference between oils that are pretty close to the same vicosity.
GC was the only oil where Blackstone uoa showed as being thicker than what the manufacturer had listed on their website. It's not thin oil.
I have been digging around on the direct Amsoil website. Their 0w30 sounds good too and I forgot a guy near me sells it locally.
Originally Posted By: Y_K
The fact that it is made in Germany? It says 'Not for sale outside US' on the bottle.
Actually, it says not for sale outside the Americas on the bottle, which means it can be sold in Canada and, presumably, Mexico. I just bought some myself up here for my next oil change, since I was out of Delvac 1.
Um, no it isn't only "solid (for) 3000" miles:
http://priuschat.com/forums/gen-ii-prius...-1-0w-30-a.html
TBN of 7.4 after almost 5500 miles.^^
"Now before anyone gets too excited, let me say that this oil was in service under very favorable conditions. Most of the time the outside air temperature was 15-25°C. Trip length was almost always over 25 km and around half of the mileage was over 100 km per trip. Speed was mostly around 85-95 km/h on rural roads."
Like I said, if it was a premium oil, it would carry the premium A5 spec.
http://www.lubrizol.com/EuropeanEngineOils/A5B508.html
ACEA A5/B5-08
Overview
ACEA A5/B5 oils are Upper Mainline lubricants. They are designed for use in high performance gasoline and light duty diesel engines that are specifically designed to use a low viscosity oil. These oils may be unsuitable for use in some engines.
The low HTHS (≤3.5cP) required by ACEA A5/B5 limits the number of additional performance claims that can be coupled with ACEA A5/B5.
Prior to ACEA 2008, ACEA A5/B5 was not usually coupled any OEM specifications. However, Ford has issued a revision to WSS-M2C913-B which raises the minimum ACEA performance level from ACEA A1/B1 to ACEA A5/B5-08. Therefore, in future some ACEA A5/B5-08 engine oils may also meet the requirements of Ford WSS-M2C913-C.
Changes
ACEA A1/B1-08
http://www.lubrizol.com/EuropeanEngineOils/A1B108.html
Overview
ACEA A1/B1 oils are Mainline lubricants. They are designed for use in gasoline and light duty diesel engines that have been specifically designed to use a low viscosity oil. ACEA A1/B1 oils are typically used in older vehicles as they do not provide the minimum performance demanded by the latest OEM specifications. These oils may be unsuitable for use in some engines.
The low HTHS (≤3.5cP) required by ACEA A1/B1 limits the number of additional performance claims that can be coupled with ACEA A1/B1.
Prior to ACEA 2008, ACEA A1/B1 was usually coupled with the Ford specification, WSS-M2C913-B. However, a new edition of this specification has been introduced by Ford which requires a higher minimum ACEA performance level of ACEA A5/B5-08. This will further reduce the range of applications for which ACEA A1/B1-08 oils are suitable.
http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=6006933
Castrol SYNTEC 0w30 European Formula is engineered to meet the Mercedes Benz 229.5 specification*. The 0w30 viscosity grade is ideal for winter conditions where low temperature pumpability is required. A unique, low-temperature formulation provides exceptional pumpability in cold weather and allows for unaided engine starts down to -40ºF. Exceeds all car and light truck manufacturer’s warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, B3, B4; VW 502 00, 505 00; MB 229.1, 229.3, 229.5; BMW LL-01; GM-LLA-025, GM-LL-B-025 and the engine protection requirements of ILSAC GF-3 for API Certified Gasoline Engine Oils
Mr. Junk, the fallacy to your argument is that you are only presenting ACEA specs. Motor oils can meet several specs simultaneously. Mobil 1 0w30 also meets API SM, ILSAC GF-4, Ford WSS-M2C929-A, GM4718, and Chrysler MS6395.
These specs when placed together on the same spider diagram not only overlap the ACEA A5/B5-08 specs, but extends beyond the performance of the ACEA specs on the same spider peformance diagram. These key areas include oxidative thickening, sludge protection, seal compatibility, rust protection, fuel economy, and piston cleanliness. All while maintaining the same wear protection peformance of the ACEA A5/B5-08 spec.
Your fallacy is known as a "false delimma" where you present only two alternatives and create the assumption that the only alternative to the ACEA A5/B5-08 spec is ACEA A1/B1. But as you see Mobil 1 0w30 also meets other specs that offers a greater performance alternative to the ACEA A5/B5-08 argument you have intentionally laid out.
That is a very good point.
I don't know of any oils that specifically state that they meet the ACEA -08 spec. currently.
I ran Mobil 1 0w30 under pretty much the same conditions that the prius guy did, all highway, mild temp's. I'm sure I could have easily gone out to 8000 miles, but like a lot of people, I get ancy around 7K and my brain starts saying "change oil", lol.
Very clearly conveyed.
Excessive worship of a single spec can be very misleading, as is often proven when people start panicking about the SM rating carried by HDEOs, thinking that its an indicator of reduced anti-wear additives. Ooops... that's not the SM rating, its the GF-4 rating that is *usually* (but not always, as in the case of HDEOs) paired with SM. The fact that A.J. refers to "the premium" A5 spec makes it clear that he's giving it a bit more credit than it alone deserves.
Quote:
Thank you for your inquiry,
A: The current Mobil 1 0w30 was not fully tested against the ACEA A5/B5 requirements but technically it should be able to meet these standards.
A: As Mobil 1 products move to new ILSAC GF-5 specification we will be updating also to new ACEA -08 standard as appropriate by grade.
MJ
Great customer service from Mobil. Here is their response.
