Originally Posted By: Garak
Originally Posted By: sir1900
We started our Corolla with Quaker State Conventional 5w20 in -31C and no problems here either!
And I did it again last night. Sill no blowup!
The W rating has more to do with how fast the engine turns over than cold start wear factors. The oil geeks and oil companies say you should use an 0W if you have to start without using a pre heater below minus 25C on more than just a few occasions. Most car engines will start down to minus 35C on 5W before you might have trouble, but it often depends on how good your battery is. You won't blow up a good engine trying but you can cook the starter motor.
