Toyota and 0w-20
Originally Posted By: CR94
Originally Posted By: Yah-Tah-Hey
WHY??? would you use a 5W-20 when you can use a 0W-20???
How 'bout less VI improver polymer to form deposits, and lower volatility (typically, depending on brand)?
That may not be the case here.
Mobil 1 Extended Performance/AP 0w-20 is 60-70% PAO, whilst the regular Mobil 1 5w-20 is 20-30% PAO, 20-30% Group III.
Also some esters.
Here's a link.
https://mobiloil.com/en/faq/ask-our-auto-experts/questions-for-auto-experts/what-is-ester-oil
Originally Posted By: mbacfp
My wife's Toyota Sienna requires 0w-20, but the book says you can use 5w-20 in an emergency, but must change back to 0w-20 next OCI.
Govt regulations. The car maker have to encourage car owners to use the same viscosity oil as used in the MPG tests for CAFE.
Also Toyota’s owners Manual (Toyota USA)states for high speed driving or high load use a higher viscosity may be used. Then it proceeds to give a viscosity temperature chart for Puerto Rico. Read deeper.
Toyota requires you to use at a minimum api sl, sm or sn oils (mine do)” recomending “resource conserving oils.
... How 'bout less VI improver polymer to form deposits, and lower volatility (typically, depending on brand)?
Different price levels. To be fair, compare "regular" to "regular," or EP to EP within the same brand and price level. By "typically," I meant typically or in general, not in every case.
Mobil 1 Extended Performance 0w20 or Mobil 1 Annual Protection 0w20 is 60-70% PAO, whilst the regular Mobil 1 5w-20 is 20-30% PAO, 20-30% Group III.
I know, I figured I'd just toss that out there though
I do not believe Toyota has made significant changes in the 3.5lt engine since it was introduced in the Sienna in 2007. They recommended 5w30 at that time. I have tried many different oils and weights over the years and none made any difference in the observed gas mileage. My butt-ometer noticed more sewing machine noise with 0w's so went back to the originally spec'd 5w30.
