08 Tundra
MN
looking at a SR5 xcab tomorrow.
150k. Plugs, serpentine belt, all filters, front/rear diff and transfer case done in July.
he's firm at 15k
Edmunds shows 16.8k...
I sold my 06 with 150k to a dealer 3 years ago, 2WD double cab. It would have been 12 years old. Dealer gave me 11k for it without haggling.
Look over the frame real good and you might have to deal with splash guards obstructing the view. Timing belt replacement should be about at 90K, if it's more than 20 or 30k past that, I'd wonder what else was being put off. I'd be a stickler at that price, it doesn't look that far out, but I'd think 8 to 10k would be more the value unless it really is next to perfect. Put me in the under $5k buyer category, as I wouldn't likely be looking at this vehicle but think I can offer some input, if I'm way off continue as necessary...Do check OBD2 codes, pending, permanent and history. I would also want to see current misfire counts, as they may not be enough to set the check engine light on but any more than a couple random, infrequent at most could be a concern.
PCV valve and transmission fluid are a couple of more service items to verify. After-thought of buying my van was I should have just drove home with no PCV valve rather than the one that was in it. Bring a new PCV valve with if possible considering if your really are ready to buy the vehicle, you could also clean the one that's in it as an option. My previous van, I used the $6 red Harbor Freight vacuum pump and pulled 4 quarts from the transmission dipstick tube and put in 4 new quarts and it needed that, both Sienna's at ~200k and an hour drive to home.
Starter under the intake manifold would be a curiosity I could get over, just know what it takes for replacement. Was it used for towing? The large bed size would be a per-requisite too. Have you gone on Toyota.com and any other resources to check vehicle history? Vehiclehistory.com is free and might be able to give locations as a 2008 from Mn would not likely be next to perfect when it comes to rust, I'd like to know it was brought up from the south fairly recently. $15k is a lot of money and you should get as much history and knowledge as you can before you go look because we all have probably done the purchase before fully realizing what we were getting.
These are obviously highly sought after, trust your instincts, might work out just fine if your comfortable with it. I did find a close comparison that has the carfax linked, slightly newer, a little higher cost $19k, but a southern history. I think I went on long enough for now...I really do want to help with advice and was awaiting the delivery of my new slightly used Innova Car Scan 5610 diagnostic code reader, good luck!
2010 Toyota Tundra 4WD Double Cab Standard Bed 5.7L
  • Like
Reactions: GON
he's firm at 15k
Post the VIN, I will run an Epic Report on it.
Supersonic posted lots of great tips. The biggest tip in my book that he posted is rust/ corrosion.
Sending you a PM...
Couple of things. Frame has been undercoated. I'm assuming it was brought back to the dealer for assessment. Transmission fluid was also done in July, just forgot about it.
Sending you a PM...
The 2010 that is for sale at a dealer listed in this thread is actually a "manufacturer buy back". Had some issues that the original owner was unwilling to live with and had the documents to have Toyota buy it back. It has been on the road for quite a while after the buy back.....
Vin # is
5TFBV54118X073844
Just ran the Epic VIN report. Report comes back very clean, has one open safety recall, but not a deal breaker IMHO. Only issue I see is it has lived in WI its entire life...... rust/ corrosion would be my concern. Price looks decent in today's market. Might be worth getting it on a lift at a body shop and have their assessment of corrosion.
I am trying to figure out how to post the EPIC VIN report.
appreciate it. I was going to run an Autocheck report, Would that show anything your report didn't. They're 24.99
Here is the report
  • Screenshot 2021-11-27 at 09-35-49 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-35-39 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-35-28 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-35-17 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-35-03 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-34-50 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-34-36 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
  • Screenshot 2021-11-27 at 09-34-10 5tfbv54118x073844-e901ff23f6bf030027a1fb495d9a6d81 pdf.webp
