08 Ford Escape - Motorcraft front pad differences
GA
We have an 08 Escape V6 that is due for front brake pads (and rotors too, most likely).
Two types of Motorcraft pads are showing as fitting: BR-1047-B (Ford Retail Spec) and BRF-1047-A.
I'm asking here because I don't have a lot of experience with Ford parts, but I know a lot of folks here do. What is the difference between these pads, if any? The BR-1047-B state Ford Retail Spec in the description, but that is the only difference I see other than price. The BRF-1047-A are a couple dollars more expensive.
Thanks.
The BRF pads are the OEM parts. If you look at the long numbers the OEM parts have a base number of 2001 while Motorcraft have 2V001 for front pads.
