I think this UOA is interesting because it is a run of conventional after two runs of synthetic. Also, at 20K miles the engine should be completely wore-in. Most of the driving was stop & go traffic around Kansas City.
This OCI was also the second on the same toyota oem oil filter (10k total). When doing this oil change I changed both the oil filter and the air filter and refilled with more conventional Penn. 5w30.
I didn't start to take the sample early enough so blackstone didn't have enough to do a flashpoint/fuel % test. This surprised me because I was able to get enough oil to get the bottle around 3/4 full. The first UOA is toyota dealer bulk 5w30. No clue what it really is, but the YB 5w30 was ran longer and didn't shear quite as badly. I think I will go back to PP but try the 5w30 instead of the 5w20.
OIL---------------YB5/30---PP5/20---PP5/20---?5/30
MI/HR on Oil------4814-----5531-----4910-----3920
MI/HR on Unit-----20222----15398----9867-----4957
Sample Date-------7/28/08--3/20/08--11/3/07--7/5/07
Make up Oil-------0--------0--------0--------0
ALUMINUM----------2--------3--------3--------3
CHROMIUM----------0--------1--------0--------0
IRON--------------5--------9--------8--------9
COPPER------------1--------3--------11-------31
LEAD--------------0--------2--------2--------1
TIN---------------0--------0--------1--------4
MOLY--------------8--------61-------53-------115
NICKEL------------0--------0--------0--------0
MANGANESE---------1--------1--------1--------1
SILVER------------0--------0--------0--------0
TITANIUM----------0--------0--------0--------0
POTASSIUM---------3--------0--------1--------4
BORON-------------68-------34-------24-------40
SILICON-----------11-------15-------18-------53
SODIUM------------4--------8--------32-------248
CALCIUM-----------2172-----2983-----2556-----1436
MAGNESIUM---------10-------21-------16-------8
PHOSPHORUS--------684------710------664------585
ZINC--------------844------876------777------736
BARIUM------------0--------0--------0--------2
SUS VISC. @ 210F--53.2-----52.2-----52.5-----52.7
cST VISC. @ 100C--8.24-----7.93-----8.03-----8.10
FLASHPOINT F------Short----390------385------385
FUEL %------------??------- ANTIFREEZE %------0.0------0.0------?-------0.0
WATER-------------0.0------0.0------0.0-----0.0
INSOLUBLES--------0.3------0.2------0.1-----0.2
TBN---------------1.7------3.2------4.3-----2.9
