06 Toyota Avalon Cartridge Oil Filter
If you're going to saddle me with a canister filter; you might as well give me back the 6 volt battery, tube-type AM radio, moon discs, 3 speed stick on the column and fuzzy dice.
Maybe my old blue suede shoes will be "NEW and IMPROVED" someday.
Canister filter.....hogwash !!
P.B.
'Believe it or not Toyota is back to using cartridge oil filters'
My 2003 BMW has a cartridge oil filter accessable from above. Easiest filter to change I've ever seen.
That's probably because the engine in your BMW (and GM's Ecotec engine) was designed with a cartridge filter in mind, so the filter is in a location that makes sense.
Here, Toyota apparently added a cartridge filter to an existing engine design. A kludge.
