Changed oil and filter on a new 2025 Lexus ES 350 F-Sport at 254 miles. I've often done early oil/filter changes on new engines, but I never cut open the filters. The 3.5L V6 Toyota filter is a replaceable cartridge type, so it was simple to view.
EVERY pleat contained easily visible particles...some only a few, some with probably over 50 particles. They were mostly silver, some copper-colored, some appeared sand-like.
I used an OEM filter and new O-rings. Filled with Mobil 1 ESP 0w30 and will run it to 5000 miles and change it again. I'll let Lexus do the 10,000 mile oil service (I'm sure they'll use 0w-20 Toyota oil), I'll change that out at 15,000 probably with Mobil 1 ESP 0w30 again, let Lexus do the 20,000 oil service, then at 25,000 I'll move to HPL 0w30 and go 10,000 miles per oil change interval from there onward until the warranty runs out at 70,000 miles. Maybe then I'll go further than 10,000 miles...but that will be a few years from now.
I think this simple V6 with no hybrid option and simple FWD is a dying breed. Wanted to get one before they get more complicated. Toyota already killed the simple V6 FWD Avalon...I think the ES 350 may be next.
