'03 F-150 2WD Rear Differential ID
northern Alabama
2003 Ford F-150 5.4L Lariat 4R70W 2WD need to identify what rear is on this vehicle. The axle code on the driver's door jamb is H9 which tells me this is a limited slip with 3.55 gear ratio. However, is it a 8.8, 9.75, other? The tag on the pumpkin bolt simply provides information about the gear oil to use, i.e. XY -75W90 which has been superceded to 75W140.
Thank you.
Can you take a picture of the housing from the back?
Can identify them via cover.
I can't imagine the 5.4 having the 8.8 behind it, a friend of mine had one with the 4.2 V6 and it had the 9.75'' differential.
IIRC, 5.4 gets a 9.75.
Just look under the truck at the axle. an 8.8 diff cover looks almost square, a 9.75 is more of a trapazoid.
Left one is an 8.8, right is 9.75.
