2003 Ford F-150 SuperCab Lariat 5.4L V8, 4R70W 4-speed 14-bolt transmission, 2WD 12-bolt rear 3.55 Limited Slip 9.75" axle
The issue is that the indicator on the steering column is offset meaning that when it shows to be in Reverse it really is in Park & on down the line the offset goes. It will never align into park & is always off one. It shifts well just doesn't indicate correctly. What causes this to happen? Is it merely an external adjustment required?
Thank you.
Thank you.
