Little background; had a partially stuck thermostat for 2 years; I thought the engine was just getting tired; turns out it was running hot. Suspected something was up, during hot weather pulling from a stop when the engine was under load, the pistons would "clang around" like there was no OP left. Had the WP and thermostat changed and noticed the difference in engine dynamics almost immediately getting onto the highway.
Figured I would do a UOA to check on the health/damage; Lab is B-S; there was a bit of RP 5W-30 as top off (1/3 qt) 2 qts makeup of Supergard 5W-30 blend and a pint of #132 (NOS) I will add this was a ARX rinse phase too. Also did 1000 mile trip in 90F @ 70-80mph and drank thru 1 of the 2 added qts.
I will using #132 as a thickener since I believe I should be running something closer to a 40weight with the # of miles.
edit:SG = Supergard; this was SN variety API
Now, onto the show--->
Al 2
Cr 0
Fe 3
Cu 2
Pb 0
Sn 0
Moly 74
Ni 0
Mn 0
Au 0
Ti 0
K 15
Boron 3
Si 4
Na 3
Ca 2163
Mg 14
Phos 639
Zn 715
Barium 0
Sus @ 210 58.5
Cst @ 100C 9.79
Fuel < .5
Glycol/H20 0
Insol .2
TBN 4.4
Quote:
It's been a few years since our last sample from your Echo, but things still look great in this engine. This was a shorter oil run than we saw previously, and that explains why wear metals dropped even lower this time around. Universal averages for this type of engine show typical wear after ~6,100 miles of oil use, and your metals are well below those levels. Potassium has been a normal find for your engine, though
we're not sure what the source is. As long as that's not from coolant, we don't see any harmful contaminants. The TBN was good at 4.4. Still going strong!
Al 2
Cr 0
Fe 3
Cu 2
Pb 0
Sn 0
Moly 74
Ni 0
Mn 0
Au 0
Ti 0
K 15
Boron 3
Si 4
Na 3
Ca 2163
Mg 14
Phos 639
Zn 715
Barium 0
Sus @ 210 58.5
Cst @ 100C 9.79
Fuel < .5
Glycol/H20 0
Insol .2
TBN 4.4
