03 bimmer UOC analysis twice Amsoil 12,
Prattville, AL
All analysis done from Blackstone Labs
Avrg provided by Blackstone for same type eng with same type oil and similiar miles.
1/13 sample was factory Euro Castrol Syn 5W30, no top off oil added. 6,448 on vehicle, 5,000 on oil. Orig oil and filter replaced at 1,448 miles, no sample taken, new eng and car not broken in.
3/08 sample was Amsoil 5w30 no oil change, no oil added just a filter change. 10,055 on vehicle, 3,609 on oil.
New sample sent 6/14 waiting for results, Amsoil 5w30, vehicle 13,075, oil 6,629. Replaced oil and filter, new oil AMsoil S2000 0w30 6.9 qrts. All oil filters were MANN from GE.
Elements Avrg - 1/13/04 - 03/08/04
Aluminum 5 - 7 - 3
Chromium 1 - 0 - 0
Iron 11 - 12 - 8
Copper 8 - 8 - 4
Lead 5 - 1 - 1
Tin 1 - 0 - 0
Molybdenum 78 - 83 - 16
Nickel 1 - 0 - 1
Manganese 1 - 3 - 1
Silver 0 - 0 - 0
Titanium 0 - 0 - 0
Potassium 2 - 6 - 3
Boron 53 - 39 - 53
Silicon 6 - 8 - 4
Sodium 7 - 4 - 2
Calcium 2,638 - 2,463 - 2,360
Magnesium 192- 141 - 719
Phosphoros 812 - 779 - 894
Zinc 976- 941 - 942
Barium 0 - 0 - 0
SUS Viscosity @ 210°F
Should be 56 - 68 - 58 - 63.1
Flashpoint in °F
Should be >365- 370 - 415
Fuel % Should be 2.0 - Antifreeze % Should be 0.0- 0.0 - 0.0
Water % Should be 0.0 - 0.0 - 0.0
Insolubles % Should be xxx - Euro Castrol - Amsoil 5w30
xxx - Syn 5w30-xxx
xxx - Veh 6,448 - veh 10,055
xxx- oil 5,000 - oil 3,609
Are you sure about that? I thought it was just the average wear/adds/miles from all the UOAs for the particular engine.
Understanding
Blackstone Laboratories' Oil Report
For Gasoline / Diesel Engines
Averages: The universal averages column is the average of all the samples we have analyzed for the particular equipment make and model. The unit/location averages column is your average wear for that particular type of equipment. They are both running averages and change with the number of samples we analyze.
Interesting post. I also have an 03 BMW 325i and dumped the factory oil at 3K miles and put in Amsoil 5w30 since the service writer at the dealer told me it was OK to use. I was then told last month that it was not OK to use so I did a change at 8K miles to GC 0W-30. I did draw a sample of the Amsoil when I drained it, but haven't sent it in yet. Should be an interesting comparison to your UOA.
vettenuts, if you get the oil analysis done at Blackstone labs ask for the Dyson Analysis package which gets his personal attention and TBN values for $35. Normal cost for this is $45. So you save money and get expert feedback on your analysis. Isn't this the reason we get our oil analysis done in the first place?
Let me know how your UOA turns out.
Thanks
[ June 21, 2004, 10:26 AM: Message edited by: Steel Blue Wind Rider ]
