http://www.automallusa.net/2002/nissan/sentra/recalls.html
Auto Recall Date:
MAR 11, 2003
Vehicle Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
Estimated Vehicles Affected: 338000
Model Affected
2002 NISSAN SENTRA
2002 Nissan Sentra Defect Summary:
ON CERTAIN VEHICLES EQUIPPED WITH THE 2.5 LITER ENGINE, THE EXHAUST PIPE HANGER PIN MAY CATCH DEBRIS FROM THE ROAD THAT COULD BE IGNITED BY CONTACT WITH THE MAIN CATALYST. ALSO ON 2002 ALTIMA AND SENTRA VEHICLES, CERTAIN ENGINE OPERATING CONDITIONS MAY CAUSE THE PRE-CATALYST TO OVERHEAT AND DAMAGE THE CATALYST SUBSTRATE.
Defect Consequence:
EITHER OF THESE TWO CONDITIONS COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL REMOVE THE PROTRUDING PORTION OF THE EXHAUST PIPE HANGER PIN. IN ADDITION TO THE CORRECTIVE ACTION, IN ORDER TO REDUCE THE RISK OF FIRE IN THE EVENT OF POOR OR IMPROPER MAINTENANCE THAT COULD RESULT IN OIL SPILLAGE, HEAT SHIELD(S) WILL BE INSTALLED ON THE PRE-CATALYST AND EXHAUST TUBE. OWNER NOTIFICATION BEGAN ON JULY 28, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT NISSAN AT 1-800-647-7261. NISSAN RECALL NOS. R3007, R3014, R3015, R3016, R3017.
ALSO ON 2002 ALTIMA AND SENTRA VEHICLES, CERTAIN ENGINE OPERATING CONDITIONS MAY CAUSE THE PRE-CATALYST TO OVERHEAT AND DAMAGE THE CATALYST SUBSTRATE. IF SUBSTRATE PARTICLES ENTER THE COMBUSTION CHAMBER, THEY COULD SCORE THE CYLINDER WALLS, RESULTING IN INCREASED OIL CONSUMPTION. IF THE ENGINE OIL LEVEL IS NOT CHECKED ON A PERIODIC BASIS AND DROPS BELOW THE LOW LEVEL, AND THE DRIVER CONTINUES TO OPERATE THE VEHICLE IGNORING NOTICEABLE ENGINE NOISE, ENGINE DAMAGE MAY OCCUR WHICH COULD RESULT IN A FIRE. THE PRE-CATALYST WILL BE TESTED TO ENSURE IT IS WORKING PROPERLY AND REPLACED IF NECESSARY. IF DAMAGE IS FOUND INSIDE THE PRE-CATALYST, IT WILL BE NECESSARY TO REPLACE THE ENGINE.
338000
Notes:
NISSAN NORTH AMERICA, INC. R3007/14/15/16/17
