02 Accord 4AT AMSOIL ATF 3010 OCI 81013 total
northern Alabama
Code:
ATF used AMSOIL ATF AMSOIL ATF AMSOIL ATF AMSOIL ATF Honda ATF Z1 Honda ATF Z1 Factory fill
Sample Date 17-Jan-2008 29-Nov-2007 Sep-11-2007 Jan-19-2007 Jan-28-2006 Jan-29-2005 Mar-13-2004
Miles on oil 3,010 2,974 15,018 15,003 12,836 10,224 21,948
Miles on car 81,013 78,003 75,011 60,011 45,008 32,172 21,948
Make-up oil None None None None None None None
Lab: Blackstone Blackstone Dyson Blackstone Blackstone Blackstone Blackstone
Wear Metals:
Iron: 40 54 104 70 60 53 59
Copper: 6 8 18 8 7 7 9
Tin: 0 0 0 0 1 1 1
Lead: 1 2 2 3 2 1 1
Chromium: 0 1 1 1 1 1 1
Nickel: 0 0 0 0 0 0 0
Aluminum: 66 82 118 74 36 27 26
Titanium: 0 0 0 0 0 0 0
Silver: 0 0 0 0 0 0 0
Additive Metals:
Calcium: 152 205 389 323 388 351 334
Magnesium: 27 44 123 136 258 221 208
Zinc: 49 82 159 206 356 320 242
Phosphorus: 443 374 239 176 2 8 3
Barium: 0 1 0 1 2 3 4
Molybdenum: 0 0 0 1 1 1 0
Antimony: NT NT 1 NT NT NT NT
Contaminant Metals:
Silicon: 12 15 24 14 10 10 11
Sodium: 14 11 8 7 4 6 9
Boron: 155 140 138 209 243 228 222
Potassium: 0 0 0 0 0 0 0
Vanadium: NT NT 0 NT NT NT NT
Manganese: 1 0 NT 1 1 0 0
Physical & Other Tests:
Viscosity 40C: NT NT 27.3 NT NT NT NT
Viscosity 100C: 6.38 6.13 5.9 45.8 44.3 45.4 45.0
TAN: 2.2 1.7 1.13 0.9 0.5 0.4 0.4
Flashpoint: 405 410 355 365 340 350 355
Oxidation: NT NT 58 NT NT NT NT
Nitration: NT NT 6 NT NT NT NT
Water: 0.0 0.0 306 (KF) 0.0 0.0 0.0 0.0
Fuel: NT NT 0.953 NT NT NT NT
TBN: NT NT 0.6 NT NT NT NT
Insolubles: 0.1 0.1 0 (soot) Trace 0 0 0
Glycol: NT NT 2.77 NT NT NT NT
VI: NT NT 174 NT NT NT NT
Sulfate: NT NT 59 NT NT NT NT
Another drain & refill of 3/7.6 qt capacity and original tranny. Still no leaks, fluid level drops (coolant included), or shifting problems. AMSOIL ATF was used as the replacement. Magnet looked slightly better this time than previous 3k OCI.
Not looking good. I'm surprised that the TAN actually went up this time. I would've also expected the Aluminum and Iron to have dropped a lot more.
Are you sure your transmission isn't failing?
No, I'm not sure. But, it's not leaking, no lights flashing, no codes set, shifts the same. I don't know what else to look for with this car.
They did at least drop this time. It has been going up since the factory fill was drained. I plan on doing another D&R w/ UOA at 84k miles.
Your metals are actually coming down. It's almost like you had some "incident" somewhere along the line. As crazy as it sounds, I would just flush the tranny out completely at home with an inexpensive Dex III and then replace with a full quantity of Amsoil ATF.
Actually, the sample with the high numbers was the sample where he switched labs.
I have ~ 92% AMSOIL in there now. What % do you suggest? Why would I do a flush with a Dex III that may or may not meet that spec (as weak as it was anyway)? Are my 3k mile OCIs not a flush? Or, do really short ATF changes show abnormally high 'wear' rates and are in no way linear & shouldn't be directly compared to 3x OCIs?
My suggestion was merely to get your ATF back to some baseline level. I have no comments on the differences in lab numbers - I just think it would be wise to clean the tranny out. It certainly will not harm it to blow some Dex III through it, go through the gears, repeat. The flush and fill does an OK job cleaning the nooks and crannies over time and renewing the fluid but it seems like the spike back 20K+ ago is only slowly tapering off.
Flush it via the lines and repeat. PITA, I know. Then fill/flush with the fluid of your choice.
To be clear: You feel the unit is doing fine?
What has prompted repeated oci's? The numbers from Terry?
Switching labs should NOT be an issue, but everyone knows that results DO (not can) vary greatly.
I do feel the unit is doing fine from a driver's position. The numbers from Terry didn't prompt the frequent drains as the 2 3k OCI from Blackstone appear much worse than the 15k OCI from Terry. I am doing (partly) the short OCIs to quickly (relative to previous OCIs) increase the % of AMSOIL in the unit.
