00 Pontiac WS6 TA, 249K miles
Texas
Make/Model: Transmission GM 4L60E Auto
Vehicle: 2000 Pontiac WS6 Trans-Am
Just purchased this one. The guy I bought it from took it in on trade, had no idea any of the history on the vehicle. Have AT & coolant samples back, sending off oil and rear diff next week. AT fluid is being flushed tomorrow and filled with Amsoil ATF.
Code:
OIL Unknown
MILES IN USE Unknown
MILES ON UNIT 249K
SAMPLE TAKEN 4/3/16
MAKE UP OIL 0
ALUMINUM 11
CHROMIUM 0
IRON 193
COPPER 42
LEAD 13
TIN 3
MOLYBDENUM 1
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 69
SILICON 11
SODIUM 9
CALCIUM 86
MAGNESIUM 1
PHOSPHORUS 218
ZINC 16
BARIUM 0
SUS @ 210F 56.1
Visc @ 100C 9.09
Flashpoint 375
Water % 0.0
Insolubles % 0.1
Blackstone Comments:
As far as wear metals are concerned, just iron was readin high in this sample. Averages for the GM 4L60E transmission are based on oil run about 20K miles, so the iron may be from a longer oil run. This would be a normal reading for a fill that's been in place about 40K miles. A long run will also allow insoluble material to accumulate from oil oxidation, and that may be what we are seeing here. The viscosity was thick for an ATF, and oxidation can also cause that. If you decide to buy the car, we suggest doing an oil change for the transmission soon. Not bad, overall.
