Recently done a pan drop, & filter change.
Sent a sample for analysis before, & after refilling with new oil. I would estimate I got about an 80% oil change
Not much of an increase in Iron, & Copper from the previous analysis, & oil viscosity still within range.
Slight increase in Aluminum, which was flagged at Upper Critical.
There was some minor filings on the filter, & Pan magnet, but very minimal to other transmissions I have worked on.
Oil is Mercon ULV ATF
- km on Oil-----Virgin----------98244 km---------137040-------137050
- Aluminum-------0--------------48---------------------65---------11
- Chromium-------0---------------0----------------------1----------0
- Copper----------0--------------48---------------------50----------8
- Iron--------------0--------------60---------------------78---------14
- Tin---------------0---------------0----------------------1-----------0
- Lead-------------0---------------0----------------------1-----------1
- Silicon-----------5--------------12---------------------12----------6
- Molybdenum---0----------------0----------------------0----------0
- Nickel-----------0----------------0----------------------3----------1
- Silver------------0----------------0----------------------0----------0
- Potassium-------0----------------2----------------------1----------0
- Sodium----------1----------------7---------------------6-----------0
- Boron-----------95--------------63--------------------55---------72
- Barium-----------0---------------0----------------------0----------0
- Calcium--------112------------110-------------------117--------105
- Magnesium------1---------------2----------------------3----------1
- Manganese------0--------------14---------------------15----------2
- Phosphorous--322------------262---------------------266-------316
- Zinc--------------0---------------5-----------------------6----------1
- TAN-----------2.05-----------0.86--
- TBN-----------2.3
- Visc 40C---------19.7--------19.6---------------------18.6-------19.4
- Visc 100C---------4.5----------4.4----------------------4.4--------4.5
- Visc Index--------147---------139---------------------154-------152
