Hi everyone,
Here is another analysis on my Altima using Amsoil's 0W30 S2K. Here are the particulars:
Vehicle: 2005 Nissan Altima 3.5 SE 5-speed M/T
Driving: Mostly high speed highway driving (3000-3500 RPM for 2 hours everyday --> 2 x 1-hour trips in each direction), also, 2-3 short trips (less than 10 minutes) each day
Most RECENT UOA (LEFT-most numbers):
Oil: Amsoil S2K 0W30
Oil Filter: Amsoil EaO12
Air Filter: Amsoil EaA in stock airbox
OCI: 7500 miles
Total Miles on vehicle: 37,500 miles
Time on oil: 4 1/2 months
Climate: Mostly below freezing, with last month or so starting to warm up outside (Toronto spring weather)
PREVIOUS UOA (RIGHT-most numbers):
Air Filter: stock Nissan paper element
OCI: 7500 miles
Total Miles on vehicle: 30,000 miles
Time on oil: 5 months
Climate: Some hot summer weather for the first 2 months, cooler temps for the next 2 months, and below freezing temps for the last month
Iron 10 / 13
Chromium 2 / 2
Lead 4 / 3
Copper 8 / 11
Tin 0 / 0
Aluminium 10 / 9
Nickel 0 / 0
Silver 0 / 0
Silicon 19 / 24
Boron 9 / 12
Sodium 1 / 7
Magnesium 21 / 29
Calcium 3760 / 3269
Barium 0 / 3
Phosphorus 1083 / 1059
Zinc 1186 / 1161
Molybdenum 1 / 0
Titanium 0 / 0
Vanadium 0 / 0
Potassium 0 / 0
Fuel Vis (100 C) 10.80 / 11.12
Water 0 / 0
Coolant NO / NO
TBN 3.19 / 3.65
Oxidation N/A / 23.0
Nitration N/A / 2.0
I'm still wondering about the slightly highish silicon numbers. The Amsoil EaA has improved it slightly, but not a whole bunch. Any thoughts? I'm pretty sure the airbox and tubes are all sealed up nicely from when I installed this filter. I do drive through construction everyday (high dust areas), but I'd assume the filter should be doing it's job if it's properly sealed. It's always very dirty every 14,000-15,000 miles when I go to change it (or clean it in the case of Amsoil's EaA). Any thoughts???
BTW, I've been extremely interested in trying out Amsoil's SM 5W40 formulation in this application. So I've filled her up with some for the next 7,500 mile OCI and I'll post up the results when they are ready.
Cheers
OCI: 7500 miles
OCI: 7500 miles
Iron 10 / 13
Chromium 2 / 2
Lead 4 / 3
Copper 8 / 11
Tin 0 / 0
Aluminium 10 / 9
Nickel 0 / 0
Silver 0 / 0
Silicon 19 / 24
Boron 9 / 12
Sodium 1 / 7
Magnesium 21 / 29
Calcium 3760 / 3269
Barium 0 / 3
Zinc 1186 / 1161
Molybdenum 1 / 0
Titanium 0 / 0
Vanadium 0 / 0
Potassium 0 / 0
Water 0 / 0
Coolant NO / NO
TBN 3.19 / 3.65
Nitration N/A / 2.0
Cheers
