Got an 06 Impala about a month ago with 18500 miles on it.First thing i did was bring it home and change the oil.While doing a routine fluid check yesterday i notice that the coolant overflow jug is almost empty and has reddish brown deposits stuck to the sides.We have only put 2300 miles on the car,surely this cant be normal .Anyway i topped off the coolant overflow jug with about a 1/2 gallon of a 60/40 mix of dexcool.Heres my question.If i change the oil now will an analysis show if the coolant is going in the motor with only 2200 miles on the oil or should i wait till the OLM says to change it and send that in for a sample? The OLM is showing 71% oil life left.By the way the oil looks very good.No signs of a massive coolant leak.
