I am confused...I want to change the transmission fluid and filter and drain the torque converter (drain plug is there!)in my 94 Town car.
I did a search on MERCON and got all kinds of conflicting reports.
The owner's manual says to use MERCON, but several folks recommend MERCON V....now I see that MERCON V may not be ok in the trans, though I was going to use it....
Then there are the MULTI-VEHICLE atf's....what the heck do I do?????????? H E L P????
