Originally Posted by 92saturnsl2
Originally Posted by Kibitoshin
You haven't been washing the undercarriage of your truck that's is why it's your fault the frame is rusting. Not my words, it's GM's since they won't issue a recall even on the steel brake lines prone to corrosion due to poor material use.
Tons of vehicles use steel brake lines-- them rotting away is a common occurrence up north, I fail to see how it's a GM problem. Most vehicles get safety inspections and these types of problems get noticed before it becomes a safety issue. In the event a brake line does fail, there is still a failsafe built in such that you will still have two wheels with brakes. Not ideal of course, but owners should be getting these things inspected on a semi-regular basis, especially in the rust belt.
It's not much of a failsafe. When I've had pads delaminate and fall off (it's happened at least once, but I swear I've had it twice), I've had no brakes until the caliper pumps up. I've been told no, the others are doing something--but when the pedal goes to the floor and the car isn't slowing down I have a very different opinion than the mechanic!
[Once my brakes are over 2 years old I inspect the pads at least once a year for rust jacking. By 5 years the pads are either shot or starting to fall off.]
