Originally Posted By: 2012AccentSE
Not sure if your Hyundai falls under the TSB that says that rattle will occur at startup with aftermarket filters. If it does, stick with OEM, if not, Fram Ultra.
Ah yeah that's right. 3 days ago I had some kind of engine knock or piston slam when the engine started until it my temp gauge came to temperature. Hasn't done it since that day... I was real worried the engine was like done or something.
Maybe that was it...
But would you say the OEM filter should still be able to handle 1 year/8 000km right, probably the same part that the US have which their oil change lists 1 year/12000km in manual.
