I've just downloaded the classic 1989 ASTM book by James A. Spearot titled "High-temperature, high-shear oil viscosity."
The following excerpt from page 53 that ends the subsection called "Engine-wear studies" is so stunning that I had to create a thread on it. It debunks everything the thick-oil people claim:
'In a series of engine-dynamometer, bearing-wear studies, Heath et al. [22] tried to "fail"
engine bearings by operating them with extremely "light" viscosity oils during severe
(although short) steady-state lugging and snap acceleration/lugging tests in a 3.8 L engine.
A well-formulated, SAE 5W oil which was expected (based on its viscometric characteristics)
to fail during the test series performed well even though its HTHS viscosity at 150 °C
and l06 s-1 was 1.4 cP (0.0014 Pa·s). Bearing distress during these tests was discovered to
be more a function of engine mechanical parameters (initial bearing clearance and oil-feed
pressure) than oil rheological properties. It is hypothesized, however, that engine-bearing
wear in customer service may be influenced by the passage of oil contaminants through
the point of minimum oil film thickness in the bearing; a variable which is controlled by
oil rheological properties.'
