2022 Ducati Multistrada V4 Pikes Peak; Motul 7100 4T 15W-50; 1.7k mi.
WA
2022 Ducati Multistrada V4 Pikes Peak, Motul 7100 4T 15W-50, 1,747 miles OCI, 9,290 total miles. Owned this bike since new in April 2022. 1st DIY oil & filter change, as all others have been part of the Annual Service dictated by the service light in August. Going forward - with such high annual service costs at the dealer, I purchased an OBDSTAR Diag. Tool to reset both the Oil Service and Annual Service minders myself.
Note: Ducati has set a 9k mi interval for oil service. Since I put on an average of 3k miles/yr., I'll likely stick to changing the oil & filter on an annual basis.
Blackstone notes: This report looks good. The viscosity is a touch low for 15W/50, and that's okay. The high flashpoint rules out excess fuel dilution as the culprit, and the slightly low viscosity didn't seem to affect wear. Wear metals look good compared to universal averages for this type of Ducati engine, which are based on ~1,400-mile intervals. No contamination from coolant, dirt, or water is present. Insolubles indicategood oil filtration at 0.2%. Nice results.
Refilled the crankcase with 4.4 qts of Moterex Top Speed 4T 15W-50 oil.
Blackstone's been sniffing too much esters.
12.87cst is barely even a 40, much less a 50. And after only 1700 miles; curious to see how much further it would have sheared.
No way I'd run the recommended 9K mile oil change interval if that were my bike. Fresh oil's cheap insurance.
Awesome bike, BTW.
The fact is if flashpoint is anywhere near 460°, in under 2,000 miles the oil wasn't performing like you most likely purchased it to perform in terms of grade. That's really low mileage for that amount of shear. The additive package is as uninspiring as I've seen in a while.
Blackstone isn't wrong, it was low on viscosity and it probably doesn't make much of a difference. Regardless of how they craft the words they are correct on both counts.
Mobil 1 10W40 4T. I looked at the Ducati manual for that bike and they recommend 15w50 but there is no requirement. It's a well-established 10W-40 that holds grade for a lot longer based on experience of most folks around here. M1 has a good additive package as well. If you're going to pay a premium price for the Motul, and it ends up at 40 grade anyway in less than 2,000 miles, the M1 is your huckleberry.
It was the Ducati dealership that opted for the Motul 7100 when the oil & filter was changed last August (2024) during its Annual Service. I'll certainly look at 10W40 for the next oil change.
Have you looked at HPL? Their Motorcycle/ATV line-up has 15w-50. They have a well documented excellence when it comes to motor oils. It’s what I use in my air cooled 650 Royal Enfield twin. That’s my suggestion. www.advlubrication.com
Thanks! I've had zero issues with bike in the past 3 years. Just annual services, S/W updates, and just recently put new Pirellis on it w/new TPMS sensors installed & activated (didn't come stock w/TPMS active <!> ).
A highlight of my time in Italy was touring the factory in Bologna. I'll always want a Ducati, just can't fit one in my life or budget at this time.
Thanks for the clarification that the dealer chose the Motul, that makes sense as this was your first DIY oil change. My fault for not being more on top of what you said in your first post.
Awesome bike, BTW.
The 9k change interval isn’t the problem here, it is clearly the oil being subpar. HPL or Amsoil would hold their own for 9k, maybe even redline I just don’t have experience with that oil.
I haven't seen a 9,000 mile HPL or Amsoil 15w50 UOA in a shared sump. Not in disagreement however that's something I'd like to see (staying in grade over 9,000 miles) with either of those oils in a shared sump before putting my money behind it.
Redline 20w50 in my ZRX 1200 was a high 40 grade upon analysis that's posted on this forum after 5,000 miles.
I've had M1 10w40 4T hold grade on one 5,000 mi oci, not quite hold grade on two other 5,000 mile OCI's.
M1 20w50 V-Twin held grade over a 5,000 mile OCI in the same bike.
It took a sample of Amsoil 20w50 V-Twin when I changed oil this weekend that's on the way to Blackstone. Almost 5,400 miles on it, looking forward to seeing how it held up.
I certainly would have trusted this out to 9k. Ended up putting 5k on it:
Bit more high strung than the Ducatti in this thread as well. HPL in now, going to sample at 3k coming up soon and see what's happening. I'm a believer that HPL and Amsoil can go the distance safely in a shared sump.
cSt is 13.1 after 1,900 miles, it's .7 away from a 30 weight (cST under 12.5), would still have 7,100 miles to go. Amsoil shows 14.6 cST as the starting spec. TBN looks good at 8.3 (a lot remaining) Amsoil shows it starts at 11.6 which is very good, IMO.
For comparison sake, M1 10w40 4T starts at cST of 13.4 and the 3 OCI's I have done ended at 11.20, 11.98 and 13.50 on +/- 5,000 mile intervals. 6.5 TBN when tested on one analysis. Can't find a published TBN from Mobil on that oil. Haven't run this oil on a number of years as I keep using different oils to test, but from start to end, not shabby on shear, but not in grade. If Mobil started this oil toward the higher end of the grade, it would stay in grade consistently in my estimation based on the relative drop in grade from the starting point.
I think base number is gonna stay pretty good for most any good oil, it comes down to how much shear takes place and the numbers we want to see at the end of an interval.
Best results I've had for staying in grade for 5,000 miles was M1 20w50 V-Twin. 5,065 mile OCI with cST of 18.84 (20.8 cST published) and 6.4 TBN. Flashpoint was tested at 410 deg f. Can't find a published TBN from Mobil on this either.
Redline 20w50 MC oil on a 5,001 mile OCI was 15.65 cST and flashpoint of 400 deg f. No TBN test done on this oil nor is one published by Redline that I can find.
I hear HPL will do custom blends on request? I'd love to see them do a monograde motorcycle oil. Zero shear guaranteed would be great for engines that are known to wreck VII's.
@jeff78, your thread from years ago about VR1 40 grade in your FZ 09 is below.
Folks that read the tread, read through it all as there is good discussion and info about a straight 40 matching up as well or better to a 20w50.
That's quite interesting. Should get a hold of them and see if they will do it then run it as a test. Would be cool to play around with.
