I actually still use the old free Malwarebytes v1.75 because the newer versions can't be disabled to run on startup, unless maybe if you have a paid subscription.
It updates the database just fine.
You can disable the start up process in your task manager. To further ensure this, in the current version go to settings > application tab then turn off auto updates, notifications and usage/threat statistics.
