Originally Posted By: IndyIan
I don't think the police will charge someone based on helmet cam footage unless some gets injured or killed?
If its clear that the driver intended to put the bike rider at risk of getting hit or crashing, I'm good with the rider vandalizing the car, as the driver deserves it. If its an unintentional near miss from a senior or a Mom trying to deal with her kids, then vandalizing their car isn't justified.
The guy on the motor bike in this case, wasn't thinking things through and was lucky not to end up dead, as he found someone crazier than him. If you ever feel the need to snap off someone mirror, make sure you have a good plan to do it unscathed!
Fascinating display of self-righteous justification for criminal behavior!
How would our hypothetical vandal (he's no longer a bike rider, just a criminal now) determine intent? You're OK with breaking off mirrors, based on his interpretation of events? Judge, Jury, and Executioner?
Wow...but a biker has no advantage other than the ability to leave...a car is a 4000# weapon, wrapped in steel, while your motorcycle is a 600# weapon wrapped in your fragile pink body...Like a Chihuahua deciding to bite a Rottweiler, a motorcyclist has everything to lose in a physical conflict.
And if the car driver decides that the person engaging in the unprovoked mirror breakage (vandalism, and on my car, several hundred $$ worth) "deserves" to be side-swiped? You're picking a fight, making things physical, when you can only lose...
If you think a driver, the Rottweiler in this case, wrapped in steel, has it in for you, then - like the Chihuahua - biting the bigger dog isn't your best bet. He might bite back, and you might not like how that works out for you.
The wisest choice is to simply leave. Your advantage is the performance of the motorcycle. No car can keep up. Conflict over, and you're safe.
You ever feel the "need to snap off someone's mirror" - let us hope that person doesn't feel the need to respond in kind: you hit my vehicle, I hit yours.
Only difference is: you broke off the mirror. He crushed you.
But in the meantime, if I don't like how you park, and feel the need to "correct" you, you'll be OK coming back to a dangling mirror, or a keyed finish? Vandalism, property damage, is OK as long as the other guy "deserved it"...right?
