https://www.autosphere.ca/carcarebusines...lite-sema-2016/
Quote:
Road Force Elite is the fastest diagnostic wheel balancer on the market and performs both a traditional balance and Road Force Measurement in less time than it takes to complete a conventional balance.
Hunter’s patented vision system determines wheel dimensions and wheel runout measurements on the Road Force Elite to save time, eliminate data entry errors, ensure accuracy and enhance ease-of-use. The vision system also completes a 3D scan of the wheel.
This scan enhances Hunter’s patented SmartWeighttechnology, making Road Force Elite the most accurate and efficient balancer on the market. The system also features automatic spoke detection, which guides technicians to place wheel weights behind the spokes.
The Road Force Elite is Hunter’s fifth generation design to utilize a loaded roller since the platform was introduced in 1997. The Road Force Elite load roller applies up to 1,250 lbs. (567 kg) of force against the tire to measure the assembly as it would perform under the weight of the vehicle. Force Matching guides the technician to index and match the lowest spot on the rim with the stiffest spot on the tire to capture the best possible ride and prevent comebacks.
With this machine, can a tire tech still screw up the match mounting and balance?
