Why specifically a Tuesday? I need to go into Discount tire because they sold me 2 tires that are 3.5 years old and one tire 2.5 years old. Getting them changed out and Tomorrow is Tuesday, so maybe I will go tomorrow.Go in on a Tuesday not before a snowstorm, tip the guy $10, and mention the vibration. They'll work with you.
Free? I have always had to pay for lifetime rotation and balance at DT (at least for the past 20+ years). May be a regional thing (either way).Take them to DT, they'll do free rebalance and rotations for the life of the tire.
You have to pay for the initial tire service when you buy the tires but, each rotation/balance is free after the initial fee is paid.Free? I have always had to pay for lifetime rotation and balance at DT (at least for the past 20+ years). May be a regional thing (either way).
So not free, you pay for lifetime rotation and balancing when you buy the tires which is what I have had to always do.You have to pay for the initial tire service when you buy the tires but, each rotation/balance is free after the initial fee is paid.
Typically slower.Why specifically a Tuesday? I need to go into Discount tire because they sold me 2 tires that are 3.5 years old and one tire 2.5 years old. Getting them changed out and Tomorrow is Tuesday, so maybe I will go tomorrow.
Right, but the reason I said it was free is because if I recall correctly the OP said he bought his tires at DT and as far as I know they only do lifetime balance and rotation on their tires.So not free, you pay for lifetime rotation and balancing when you buy the tires which is what I have had to always do.
This is the balancer that all of my local Discount Tire Stores have:As mentioned likely the only balancer a discount tire store even has is a recent or latest hunter road force machine. Properly install assembly on balancer and it will read road force and balance for each wheel.
unless there is a road force concern there is no real reason to correct it.
likely your tires are out of balance. Lots of truck tires especially go out of balance quickly after putting some miles on them
You are both right: dad pays and son goes in for free rotation and balanceSo not free, you pay for lifetime rotation and balancing when you buy the tires which is what I have had to always do.
This post is exactly like what I went through. For a minute, I thought this post was on I had written.Used to use a local tire shop, to keep it local. HORRIBLE vibration after new tires installed. Brought it back 3 times. They mentioned suspension and steering blah blah. Took it to a national retailer, paid for a balance, PERFECT. Went back to the local store and talked to a manager and told them I'd never be back. The national retailer mentioned something about using the correct nut thingy to screw a tire onto the balancer and that often a tech will use one that doesn't necessarily fit the rim correctly but they are trained to do everything EXACTLY as specified by their trainings. But who knows.
Long story short, some places know how to balance, some don't.
The stores here have two choices:Right, but the reason I said it was free is because if I recall correctly the OP said he bought his tires at DT and as far as I know they only do lifetime balance and rotation on their tires.
agreed! it seems to be very hard for some to use one (set of ) weight on the inside and one set on the outside or behind the spokes.It's a lot harder to balance a tire/wheel correctly, than it LOOKS !
Also the arbors will get wear spots on the common hub diameters, which will lead to poor results.The national retailer mentioned something about using the correct nut thingy to screw a tire onto the balancer and that often a tech will use one that doesn't necessarily fit the rim correctly
1. One time mount and balancing included with cost of tire
2. Lifetime tire rotation and balancing in addtion to cost of tires
I am not sure if it is the same everywhere.
I buy it everytime even on the OEM tires. It's a good deal and like you said saves the back muscles. I would not enjoy wrestling the 5 tires on my Jeep every 5K milesThey may do that here too but they've always figured in lifetime rotation/balancing when I've used them so I've never questioned it. For me it's convenient and keeps me from being out in 0*F or 110*F weather rotating my own tires.
Doing my own rotations wouldn't be so bad if I had a air conditioned/heated garage to work in and 2 floor jacks but with only one floor jack it involves a lot more jacking and tire changing. Jack up front left corner remove wheel put on spare, jack up rear left corner take tire off put front left on. Go back to front left corner jack it up again remove spare put left rear tire on. Now we can do the same thing all over again on the right side and when we're all done the wheels still haven't been re-balanced.I buy it everytime even on the OEM tires. It's a good deal and like you said saves the back muscles. I would not enjoy wrestling the 5 tires on my Jeep every 5K miles![]()
My HHR would lift the entire side of the car if I jacked 6-12 inches rearward of the firewall. Depending on what you think of your frame rails at this point it may be an option.Doing my own rotations wouldn't be so bad if I had a air conditioned/heated garage to work in and 2 floor jacks but with only one floor jack it involves a lot more jacking and tire changing. Jack up front left corner remove wheel put on spare, jack up rear left corner take tire off put front left on. Go back to front left corner jack it up again remove spare put left rear tire on. Now we can do the same thing all over again on the right side and when we're all done the wheels still haven't been re-balanced.
