Originally Posted By: Trav
I don't buy it. I ran my 92 Honda CBR1000F SC24 over 200K on Castrol RS 10w60 which is a true synthetic, compression and wear were all within manufacturers spec for a new engine when I checked the parts with a micrometer, It needed the cam chain which stretched.
The accepted life expectancy of this engine is about 100K, the bike has over 300K on it now same engine.
BTW I did not extend the OCI.
So you do buy it, (synthetic oil) and evidently it was worth buying, but it doesn't, of course, prove that a non-synthetic oil, perhaps used at a shorter OCI, wouldn't have given you the comparable performance.
Thats a pretty high end motorcycle and I believe it runs a car-type oil filter. On the smaller, older engine designs I'm familiar with, and typical here, there is no filtration (or only a centrifugal "filter") which also arguably contra-indicates long OCI's and so reduces the benefit of synthetic oil.
