Originally Posted By: sleddriver
Originally Posted By: Alfred_B
Take it easy, put aside your misogyny and drive calmly.
I don't see what the big deal is with these situations - normal occurrences on the roads. Sounds like you are not used to the traffic "rules of chaos" of that particular area.
The term 'misogyny' is a sexist, politically loaded term used by the politically-correct crowd. Obviously you read politics into everything. You just can't help yourself, can you?
"I don't see what the big deal is..." this section borders on creepy, warped and weird. Further, you come off as out-of-touch, clueless and detached. However, I'm willing to bet you'd FREAK if it happened to you once...much less three times in a single day. Your type typically does. There really are no 'rights' nor 'boundaries' in your world, are there? It's all relative, eh?
You probably drive like the very people I mentioned....and can't understand what all the fuss is about.
ad hominem immediately... SMH
