WD-40 Launches Grease Line
For the first time in company history, WD-40 is adding greases to its product slate with its WD-40 Specialist Greases for automotive, agricultural, marine and construction equipment. The greases are interchangeable to prevent cross-contamination that may compromise performance, the company says, while protecting against corrosion, high temperatures and extreme conditions. The product line includes a multipurpose grease, two greases for improved load-carrying ability in heavy-duty trucks and a marine grade grease to protect trailer wheel bearings, trailer chassis, water pumps, anchor reels and outboard motors against rust. The products are available in the United States at Home Depot stores. Web: www.wd40specialist.com
Interesting.....
Interesting.....
