Why bother with additives - its all just mineral oil
michigan
I was looking up the MSDS of Lucas UCL because i got some free. I noticed that is all just Distillates, petroleum, hydrotreated heavy paraffinic oils ,which is just a Synonym for mineral oil.
I found this chart that explains about how much cheap mineral oil we have in many house hold products.
I think i will just stop using any additives .
Its just a waste of money.
Brand Category Form Percent
WD-40 Bike Chain Lubricant, Wet Lube-10/16/2014 Arts & Crafts liquid Valvoline NextGen SynPower Full Synthetic Motor Oil, 5W-20 Grade Auto Products liquid 10.0-15.0
Valvoline NextGen SynPower Full Synthetic Motor Oil, 10W-30 Grade Auto Products liquid 10.0-15.0
3-IN-ONE Professional Grade Pneumatic Tool Oil-Old Product Auto Products liquid 40.0-60.0
Rislone Compression Repair with Ring Seal Auto Products liquid >75
Rislone High-Performance Oil Treatment 710 Auto Products liquid >50
CRC Motor Treatment 05316-01/18/2012 Auto Products liquid 45.0-55.0
Pyroil Power Steering Fluid with Stop Leak-11/05/2012 Auto Products liquid 90.0-100.0
Pyroil Power Steering Fluid-11/05/2012 Auto Products liquid 90.0-100.0
Valvoline DEX-MERC Automatic Transmission Fluid-07/30/2013 Auto Products liquid 90.0-100.0
Valvoline Import Multi-Vehicle Full Synthetic Automatic Transmission Fluid-09/04/2013 Auto Products liquid 60.0-70.0
Valvoline Type F Automatic Transmission Fluid-07/30/2013 Auto Products liquid 90.0-100.0
STP Power Steering Fluid + Stop Leak-06/19/2015 Auto Products liquid 80.0-100.0
STP Pro Formula Conventional Motor Oil-11/20/2014 Auto Products liquid 30.0-90.0
STP Syn Full Synthetic Motor Oil-11/20/2014 Auto Products liquid 30.0-70.0
Havoline Formula 3 Motor Oils Auto Products liquid 20.00-34.99
Quaker State Dexron III/Mercon Automatic Transmission Fluid Auto Products liquid Quaker State Itasca 2 Cycle Motorcycle Oil Auto Products liquid Quaker State Itasca Marine SAE 80W-90EP Outboard Gear Lubricant-discontinued Auto Products liquid Quaker State Itasca 2 Cycle HP Snowmobile Engine Oil TC-W3 Auto Products liquid Quaker State 4 x 4 Synthetic Blend ATF Dexron III/Mercon V Auto Products liquid Anti-Seize Lubricant-Old Product Auto Products aerosol 15.0-20.0
STP Fuel Injector/Carburetor Cleaner-08/07/1998-Old Product Auto Products liquid 5.0-10.0
STP Gas Treatment-09/30/1998-Old Product Auto Products liquid 0-30.0
STP Super Concentrated Fuel Injector Cleaner-Old Product Auto Products liquid STP Fuel Injector and Carburetor Treatment 12 Fl. Oz.-Old Product Auto Products liquid Sprayway Industrial Penetrating Oil No. 764-Old Product Auto Products aerosol 30.0-40.0
Mercury Marine 4-Stroke Outboard Oil, 10W-30 Auto Products liquid 30-50
Mercury Marine MerCruiser Diesel Engine Oil, 15W-40 Auto Products liquid 0-20.0
Mercury Marine Premium Plus 2-Cycle TC-W3 Outboard Oil Auto Products liquid 0-4.0
STP Universal Power Steering Fluid-04/01/2003-Old Product Auto Products fluid 90-100
Mobil Dexron VI ATF (Automatic Transmission Fluid) Auto Products liquid 30-40
Prestone Stops Leaks-08/26/2011 Auto Products slurry 60.0-85.0
Prestone Super Radiator Anti-Rust Auto Products liquid 5.0-20.0
Valvoline NextGen SynPower Full Synthetic Motor Oil, 5W-30 Grade Auto Products liquid 15.0-20.0
Valvoline Power Steering Fluid-Old Product Auto Products liquid 90.0-100.0
Bars Leaks Engine Oil Smoke Away Concentrate-old product Auto Products liquid >50
Rislone Engine Treatment Auto Products liquid >50
Rislone Ring Seal Smoke Repair Auto Products liquid >50
Pyroil Automatic Transmission Fluid with Stop Leak-04/08/2014 Auto Products liquid 80.0-90.0
Valvoline ATF+4 Full Synthetic Automatic Transmission Fluid-11/21/2014 Auto Products liquid 20.0-30.0
Valvoline DEXRON VI Full Synthetic Automatic Transmission Fluid-07/03/2013 Auto Products liquid 50.0-60.0
Valvoline Power Steering Fluid-11/05/2012 Auto Products liquid 90.0-100.0
WD-40 Multi-Use Product-10/16/2014 Auto Products liquid Saikil Bicycle Chain Lubricant-03/08/2016 Auto Products liquid STP Power Steering Fluid-06/19/2015 Auto Products liquid 90.0-100.0
STP Smoke Treatment-05/10/2015 Auto Products liquid 60.0-100.0
STP Synthetic Oil Treatment-09/23/2015 Auto Products liquid 40.0-60.0
Trouble Free Rust Buster Auto Products aerosol
Wal-Mart Super Tech Marine High Viscosity 80W-90 Lower Unit Gear Lubricant Auto Products liquid Quaker State ATV Oil-discontinued Auto Products liquid Quaker State High Performance Gear Lubricant 85W-90 85W-140 Auto Products liquid Quaker State Marine 2 Cycle TC W3 Oil Auto Products liquid Quaker State Multipurpose 80W-90 GL-4 Gear Lubricant Auto Products liquid Quaker State Power Steering Fluid Auto Products liquid Castrol Dexron III Auto Transmission Fluid-discontinued Auto Products liquid STP Fuel Injector/Carburetor Cleaner-Old Product Auto Products liquid STP Gas Treatment-Old Product Auto Products liquid 1.0-30.0
STP Oxygenated Gas Treatment-12/24/1998-Discontinued Product Auto Products liquid 0-30.0
Anti-Seize Lubricant-11/27/2000-Old Product Auto Products aerosol 5.0-15.0
STP Power Steering Fluid 12 Fl. Oz.-Old Product Auto Products liquid 0-100
Valvoline ATV 4-Stroke Motor Oil Auto Products liquid 69-89
Mercury Marine 4-Cycle, 4-Stroke, MerCruiser Synthetic Blend Outboard Oil, 25W-40 Auto Products liquid 0-15.0
Mercury Marine MerCruiser 4-Cycle Engine Oil, 25W-40 Auto Products liquid 0-10.0
Mercury Marine Power Steering Fluid, SAE 0W30 Auto Products liquid Mercury Marine U-Joint and Gymbal Bearing Lubricant Auto Products grease >96
BP Select Motor Oil 5W20 Auto Products liquid 90-95
STP Power Steering Fluid-06/01/2011-Old Product Auto Products liquid 90.0-100.0
3-IN-ONE Professional Grade 100 Percent Pneumatic Tool Oil-07/31/2014 Commercial / Institutional liquid 40.0-60.0
Sherwin-Williams Duration Exterior Coating Flat Latex Home Maintenance liquid 1
Sherwin-Williams Exterior Accents Latex Satin, Chroma Base Home Maintenance liquid 1
Sherwin-Williams Illusions Metallic Technique Finishes, Gold Home Maintenance liquid 1
Sherwin-Williams Color Accents Interior Latex Flat Finish, Ultradeep Home Maintenance liquid 1
CertainTeed Basement Wall Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed CertaSound Acoustical Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Foil-Faced Fiber Glass Building Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Noise Reducer Sound Batts-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Speedy Bandit Fiber Glass Building Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Optima Blowing Wool-09/30/2004 Home Maintenance fiber 2.5
Thompsons WaterSeal Clear Multi-Surface Waterproofer 1010 Home Maintenance liquid 21
Pratt & Lambert Accolade Interior Semigloss, Latex Wall Finish, Designer White-Base, RZ4190 Home Maintenance liquid 1
3-IN-ONE Multi-Purpose PTFE Lubricant-07/31/2014 Home Maintenance liquid Sherwin-Williams Duration Exterior Coating Satin Latex, Extra White Home Maintenance liquid 1
Sherwin-Williams Illusions Metallic Technique Finishes, Copper Home Maintenance liquid 1
Sherwin-Williams Illusions Metallic Technique Finishes, Silver Home Maintenance liquid 1
Sprayway Hoil Penetrating Oil and Rust Preventative No.961-Old Product Home Maintenance aerosol 45-50
CertainTeed Unfaced and Kraft Faced Building Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed EZR Fiber Glass Insulation-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Masonry Wall Batts-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed Speedy Tabless Batts-10/15/2004 Home Maintenance fiber 0.5-1.5
CertainTeed InsulSafe 4 Premium Blowing Wool-09/30/2004 Home Maintenance fiber 2.5
Magic Complete Marble & Granite Magic, Aerosol-05/01/2008-Old Product Home Maintenance aerosol Thompsons WaterSeal Clear Multi-Surface Waterproofer, Aerosol 10100 Home Maintenance aerosol 16
Permatex Chain Lube-Old Product Home Maintenance aerosol 10.0-30.0
Kitchen Magic-Old Product Inside the Home aerosol Panel Magic-Old Product Inside the Home aerosol
Howard Orange Oil Furniture Polish Inside the Home liquid Magic Kitchen Magic, Aerosol-12/17/2006-Old Product Inside the Home aerosol Magic American Marble & Granite Magic-Old Product Inside the Home aerosol Furniture Magic-Old Product Inside the Home aerosol Howard Feed-N-Wax Inside the Home liquid
Magic Complete Cabinet and Wood Magic, Aerosol-Old Product Inside the Home aerosol Arnold Premium 4Cycle Lawn Mower Oil Landscape/Yard liquid 80-90
Homelite Premium 2 Cycle Exact Mix Landscape/Yard liquid Quaker State Lawn & Garden 2 Cycle Engine Oil-discontinued Landscape/Yard liquid Thompsons WaterSeal Waterproofer Plus Clear Wood Protector 1180 Landscape/Yard liquid 19
40:1 Poulan 2 Cycle Engine Oil with Stabilizer Landscape/Yard liquid 70-80
Neutrogena Sunblock SPF 30-PABA Free Personal Care paste
Revlon Professional Liquid Quick Dry Nail Enamel Personal Care liquid
Aussie Instant Daily Conditioner-Old Product Personal Care liquid
Sure Roll On Deodorant-Old Product Personal Care liquid
Farnam Wipe, Original Formula Fly Protectant-04/28/2017 Pet Care liquid 37.24
Note: Brand names are trademarks of their respective holders.
Information is extracted from Consumer Product Information Database ©2001-2018 by DeLima Associates.
All rights reserved.
Originally Posted By: skyactiv
I'm not reading all that.
The hip internet-speak way to say that these days is TL;DR. Means "Too Long; Didn't Read."
Here is the bottom 7 products listed: (cut & pasted-Ha-Ha)
1) wood sealer
1) 2 cycle oil
1) sunblock
1) nail polish
1) hair conditioner
1) deodorant
1) insect repellant
There are probably MANY examples in each of these 7 product categories alone. The list could be 150 times longer.
Ergo, this list is ridiculously spotty.
That's not to say it's completely useless or uninspiring. EX: I always thought the drying element in deodorants was alcohol.
1) wood sealer
1) 2 cycle oil
1) sunblock
1) nail polish
1) hair conditioner
1) deodorant
1) insect repellant
Haha I use two of those products :P
The Neutrogena sunblock and the Aussie conditioner
Isn't it TL;DNR to emphasize the NOT?
Also applies for me here...
TTFN
I like Lucas products and seafoam as well i am a hobbiest who enjoys small engine repair and notice a difference in a good way with certain products which I am sure are all so very different than baby oil as you claim.
Thanks
Originally Posted By: CT8
Engine oil is mostly oil.
With some additives.
and marketing, and sexy bottles with easy pour spouts.
Today's date is Aug 1st, not Apr 1st. Surely people understand what has been "discovered" is the the carrier oil. And...not everything is disclosed in the MSDS.
