Originally Posted By: bbhero
I could be seeing it in a off, wrong way... But it sure looks like it's facing the other way around. Look at the filter all together pics. The openings are kind of narrow but open just a bit. not as much as I would like but open just a bit. Then look at the tube with the media off... That metal isn't flared outwards. It seems to be more open. Like it is more open on the side against the media, then coming to a narrow opening on the opposite side in the center of the tube.
The metal is bent towards the center of the tube. So the louvers protrude out into the center tube. That way the surface that the media sits up against is basically smooth so it doesn't cut in to the media.
