Hello everyone,
I have a 1997 Integra and I managed to remove the oil pan but the gasket is baked on like hard plastic? Are there any solvents I can soak it in for it to be easier to remove? I heard about using a blow torch but that is the last option, please see other questions below
Can I light the gasket on fire somehow?
Should I avoid a gasket scrapper?
What will really help to remove it best?
Thank you
Thank you
