Triple_Se7en
$50 Site Donor 2024
Originally Posted By: bbhero
Well, I have a friend of my lady who needs to have the oil changed in her 2011 Nissan Rogue SL 2.5. This is a freebie to help her save the money. It sees mostly in town short trips and has about 70k miles on it. So what oil would you all run it in? I have the following available... 1) Havoline Pro DS 5w30 2) Motorcraft 5w30 3) Castrol Magnatec 5w30 4) Formula Shell 5w30 or as a distant possibility 5) Castrol 0w30
Oil filters I have are 1) Wix 57356 2) Fram TG 3) Royal Purple 10-2867 4) Mobil 1 M1-110
I am thinking about running the Castrol Magnatec 5w30 and a Fram TG on there. What would y'all do??
Is this an ECOTEC engine that calls for 0w-20 synthetic? If it is, then please don;t harm that girl friend's engine, should overheating occur and that engine needs to operate for an extra 1.5 miles back home and under extra heat from losing coolant.
All you-people using these ECOTEC-type engines, use synthetic. I know someone that didn't and the vehicle overheated two short blocks from the safety of her house. The neighborhood is not the greatest and she tried to nurse that vehicle home.
Turned out to be a big mistake, for she had conventional oil in her ECOTEC, not synthetic which handles heat a little better. Had it been synthetic, she may have made it home and saved that engine.
