Coworker has a 2006 Mazda 3 (stickshift) and apparently it threw a cylinder 1 misfire code this morning. Runs ok but I guess it stumbles (if not outright misses) in the 3,200 to 3,700 rpm range. Fine outside that range. He looked up the code (has Torq to scan) and apparently someone said they had this cylinder 1 misfire and replacing the valve cover gasket fixed. We took a quick look and it doesn't look like a bad job--but it's still the middle of winter.
I said he should pull the coils (it's coil on plug) and check for oil. If none is found then he should pull the plugs (they have 40k on them) and check; and perhaps just change, if it's close to time.
What I'm not sure about: if oil is found, could he just clean off the coil (brake cleaner?), pull the plug so as to drain the oil; clean the plug off (brake cleaner?), and reassemble. That way he can fix when warmer. [I know it'll smoke at startup while burning off the oil.] This correct?
Also: any other suggestions for him to look into?
