Originally Posted By: Shannow
Originally Posted By: 69GTX
Oil is the thickest before you cold start the car. The colder it is outside, and the longer the car has sat, the lower the viscosity...regardless if it's a multi-grade or straight weight oil.
From that point on, the oil only gets thinner as oil temp rises. It would be ideal if the oil at startup were around 8-14 cSt (operating viscosity ranges). It's actually up to 1,000X to 3,000X that during an extreme cold start in say -35/-40 deg C temps. Time to read the new Motor Oil University...or even the old one.
I disagree...if the oil was at operational viscosity at startup, it would need all the AW additives to be fully functional from dead cold...which they don't.
The thicker, cold oil does a fair bit of hydrodynamic lubrication in the period between first start, and thin/additive controlled wear.
Logically, if the oil is at operational viscosity at startup, your car was already hot and just turned off. But I would agree that you'd want the oil preheated at S/U if possible so that the AW additives are functioning. And that's achievable with today's technology. Can there be such a thing as an oil that starts off at 10 cSt at -20 deg C and can function in a car's engine at 100 deg C?
