Originally Posted By: edyvw
Better how? I have both and don't really see a difference other than the HD shifts much firmer, but that is due to the SRT programming, not the unit itself
I understand the HD unit to be "tougher", and it would have to be, but I just don't see how that makes it better, assuming both units are appropriate for the application they are in. The little Pentastar is never going to be hitting the main shaft with 470lb-ft for example.
I base my comment of better as per a discussion with a tech who works in a high volume Chrysler dealership. Maybe I asked him a loaded question,
which went along these lines: Which is the better ZF transmission, the one behind the hemi, or the one behind the Pentastar? His answer was hands down the unit that goes with the hemi. He also said something about the filter and pan are changed as a unit, and quite expensive. I also have a good friend who owns a Pentastar GC with the 8 speed that had his replaced under warranty. Like you he also owns a Ram Hemi PU which is used to tow quite often. He's at 10K miles more than the GC had when the unit let go, and has zero issues. His comments where similar to yours, the shift is firmer and more authoritative.
It should be interesting to see what the 2018 Wrangler gets, I'm thinking the light duty one.
The HD unit is the one that also goes to BMW, Audi, Rolls Royce, etc.
Those units have filter and pan integrated (same like my 6 speed ZF on X5) and actually if you buy it yourself is not as expensive. I am about to change fluid and pan and filter unit is $98 on Amazon, ZF made. Pita is fluid which is $26 per liter.
Also, those units in BMW, Audi and what Dodge calls HD unit in RAM have carbon clutch plates.
I read about the fluid being expensive. I think some of them are stating they're supposed to be filled for life. Good luck with that as many of us here would say. Good on you for servicing it. I could easily live with the $98 cost for the pan and filter. I heard early reports of it costing $200 or more. I would imagine the cost of the fluid will come down eventually as well. Enjoy!
They keep price. But, that is ZF fluid. Now, you can use fluids that also meet ZF requirements, and for example Valvoline Maxlife Full Synthetic meets it, Castrols, Mobil1, Redline etc. I decided to use ZF6 since I am not going to do flush, of course. So do not want to mix fluids.
As for change interval, this is tricky. Each car manufacturer has its own recommendation. BMW claims it is life fluid. If to be changed, they recommend on 100K. ZF on other hand recommends change between 60K and 75K. I am going with ZF in this case!
