Originally Posted By: BrocLuno
ATF is a fine lubricant. Just ask the odd 200,000 mile old tranny how that went. We change engine oil at 5K, but tranny fluid at 50K and you think there is anything wrong with ATF as a lubricant ...
Kerosene is somewhat useless. But it will penetrate some things like tape residue.
Why not just use ATF for the lube part? Or, better yet, Rem Oil
Well this was meant to be a question for discussion... for academics, but that went right out the window when everybody failed to read the first post and assumed I was asking about the bore cleaner version even though I wasn't even though I specified as much.
So you ask- "Why not just use ATF for the lube part?" Well... I could, but that also wasn't the question.
I know that there are countless other lubes out there (I have several)- but that wasn't the point of this thread. In case everyone missed it, here it is again- What types of firearms would a mixture of ATF, kerosene and lanolin be suited for? Any? None? Too thin? One person said it'd be too thin, but for what? It is at least thicker than Rem Oil.
Lastly, it is not my intention to be combative, but practically the whole point of this thread was glossed over and no relevant answers were given.
