I have 4.10 gears and a fully optioned 4X4 explorer with an open diff (why I don't know). I think it could do a bit better in the snow. Don't want anything too aggressive because locked wheels could mean lots of oversteer. This is the unit with the carbon fiber TL clutches.
So, for about $300 with all new axle seals and bearings (pinion being left alone) I can install a cobra carrier. All I have to worry about is backlash so I will get a shim kit(maybe I will get lucky with the old shims).
Questions:
1) 75W90 or 75W140? No Towing. Thinking of using either VV or M1. Later Explorers do spec the heavier fluid, but that could be because of towing or the IRS which has much less fluid. The Mustangs spec the lower weight. Honestly I could probably get away with 80W90(what is listed in the 96 manual). That is what is in there now, VV synblend.
2) Add the limited slip fluid or rely on what is already in the fluid. I called valvoline, they said you absolutely don't need LS fluid with their product.
Questions:
