Originally Posted By: JustinH
Originally Posted By: Al
Check dipstick when cold. Thoroughly wipe it off and then install. Only read once. Further readings will be inaccurate.
If the dipstick is dark. Take fine sandpaper and make the end shiny. Makes a huge difference.
But why follow the OCI when you are using the wrong oil? No reason not to use 20 wt. Just an opinion.
Fill cap says 5w20.
Owners manual lists 3 oil grades as appropriate. 5w20, 5w30, 10w30.
Just purchased 5w30 chevron supreme on amazon for $11, and some OEM filters and washers. I will sample it at 3750 miles, and I'd bet I can be safe to run it longer than that.
Just want to get a baseline as to if I have any fuel in the oil, etc..
In our Elantra, I'm running 5w20 in the winter, and 5w30 in the summer. The owners manual supports doing this. With pennzoil synthetics i have been doing 7500 mile changes.
Fill cap says 5w20.
