HI,
Honda recommand ATF DW1-1 as transmission oïl in my 2011 CRV.
Do you see any inconveniant by using Amsoil ATF oïl ? can it be mix ?
thanks
Use only Honda ATF DW-1 (automatic
transmission f luid). Do not mix with
other transmission f luids.
Using transmission f luid other than
Honda ATF DW-1 may cause
deterioration in transmission operation
and durability, and could result in
damage to the transmission.
Damage resulting from the use of
transmission f luid other than Honda
ATF DW-1 is not covered by the Honda
new vehicle warranty.
thanks
