Originally Posted By: buster
I called Chevron. The only concern of over dosing on Techron is thinning out the oil, but that is most likely in cars with worn piston rings. My car is new and does not consume any oil however I will do an early oil change this time to play it safe.
Have you done any UOA's? Our Acadia doesn't use any oil at all but the UOA's show high fuel dilution. If your UOA's don't show any fuel dilution then you should be fine I would thnk.
